Garmin Nuvi 255W — это GPS-навигатор (система глобального позиционирования).
Is looping on Starr up
When I switch it on garmin logo appear then it stays on for a minute or two then it's switch off then on again but it don't start the maps
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Most likely an OS error try updating your nuvi using the Software listed on there website.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
My pc can't pick up garmin at awl
из
So just to be clear you have the software on your PC?
If yes Then do a manual reset there should be a small hole somewhere on the nuvi it self as Jayeff states in his post do that then try connecting to your PC
из
Hi,
Have you tried resetting it?
There is either a reset button on the bottom (it may be hidden by a sticker) or if it is not there then try sliding the power button on/off across and holding it for 8 seconds to see if this resets the device.
If neither of these work, try clearing the User data in the device by holding your finger on the lower-right corner of the Nüvi screen while turning it on. Keep your finger pressed until the pop-up window appears. Touch yes. All original settings will be restored. Be aware that any items that you have saved will be erased.
Счет 2
Добавьте свой ответ
Frederick Scheepers буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 23
За все время: 935
