Контроллер PS4 модели CUH-ZCT1. Выпущенный 15 ноября 2013 года компанией Sony Computer Entertainment, этот шестиосевой (six-axis) контроллер с литий-ионным аккумулятором 3,7 В несложен в ремонте. (ПРИМЕЧАНИЕ: руководство по разборке (teardown) НЕ ПРЕДНАЗНАЧЕНО для этой модели)
The square button is not work
The square button when I press on button is not work what I do
Это хороший вопрос?
Счет 10
2 Комментариев
you can replace the square button. you can order the motherboard from the IFIXIT site. and you can see how to fix also on this site.
из Поделиться
Yo no lie all I just did was get some scissors and pull up tried to wedge it in the side and just keep doing that trying to take the square button out than just pull up Spotify and keep trying use square till it work I swear try it
из Поделиться
Добавить комментарий
5 Ответов
Выбранное решение
Hi Amjad!
You can find our repair guides here for fixing or replacing the buttons on this controller:
Замена кнопок контроллера DualShock 4 (CUH-ZCT1U)
We also sell replacement parts for the controller if you need them. These are the buttons:
DualShock 4 Controller Action Button Covers
Includes the plastic action button covers and the button gasket Изображение
Товар
Был ли этот ответ полезен?
Счет 4
Make sure to clean the connection to from the conductive film to the motherboard.
https://youtu.be/Lx3La8a169Q
Счет 2
Thanks on the bottom of the phones keyboard, the square button doesn't work. How do I get it back working?
Счет 1
1 Комментарий:
How to make this work
из Поделиться
I was having issues with my left analog stick constantly drifting. Took the controller apart and cleaned it. Now it works great……except the square button doesn't work now. I'm thinking it's the clear film. May have a tear but I can't tell. Hope that info helps someone. Still working on my square button. Thinking about buying another mother board.
Счет 1
1 Комментарий:
I did same thing as Jason above, took controller apart cleaned it thoroughly put back together and square button not working.
из Поделиться
Exact same thing happened to me cleaned joysticks sensors and now square button doesn’t respond, I can see and feel it makes contact but no response I was thinking it was the ribbon strip because a couple of connections on the ribbon were folded back from disconnecting and reconnecting so many times maybe this could be the issue?
Счет 0
Добавьте свой ответ
Amjad Badkook буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 15
За последние 30 дней: 81
За все время: 88,473
