недорогой ноутбук с базовой игровой производительностью; включает модели G50-30, G50-45, G50-70, G50-80.
Bluetooth and USB cant connect
I don't know what happen but all of sudden my laptop can't connect to my phone via USB and also my laptop's Bluetooth isn't working correctly either! it doesn't work.
Это хороший вопрос?
Счет 0
4 Комментариев
Hi,
What is the exact model number of your laptop?
What OS is installed?
Have you checked in "Device Manager" that the BT is working properly?
Can you connect any other USB devices OK?
Have you checked the USB Controllers in Device Manager are OK?
Have you tried restarting the laptop at all?
What have you tried?
из
it say BT is not working properly my
My laptop only can connect via PTP not MTP
It is windows 8
из
Hi @nazri12330,
What is the "exact" model number of your laptop? This will help in finding the correct BT drivers for your laptop.
из
it is lenovo g40
из
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Here is a link to the drivers for your laptop.
Select Bluetooth and Modem in the Component box on the page and then download the BT drivers and install them in your laptop.
Only download the BT drivers at this stage. Once you have fixed the BT problem you can go on and see what else needs to be fixed.
http://support.lenovo.com/au/en/products...
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
nazri12330 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 649
