BLU TANK II T193 Аккумулятор-монстр, 30 дней в режиме ожидания Разработано BLU в Майами | Собрано в Китае www.bluproducts.com
Calls will not go through
When I try to make a call, it shows that it is dialing, but then a "Failed" message comes up.
This is a new problem.
I am also wondering why the phone screen says "Emergency" at the top left corner.
Your suggestions would be very much appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
from the sound of it you are just in an area with really bad reception. try moving to a different location where you have full bars and it says that you have full data connectivity also. sometimes my phone will have bars but if it does not show data connectivity then it will not allow me to make any calls except "emergency only"
hopefully this helps you out and you are dialing away soon
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
Thank you very much for responding. I ended up calling the service provider and , after much trying of this and that, determined that the phone itself is the problem. Oh, well, at least it was not an expensive one.
из
that is great to hear. well i hope that by now you are calling away to all your friends lol. good luck in the future
из
@carold make sure the phone is reading the sim card
из
Try to take out the SIM card, clean it then re-insert it. Sounds like it isnt recognising it.
Счет 0
2 Комментариев:
Turns out the SIM was OK and the phone was bad. I really appreciate all the suggestions I got.
из
you are welcome
из
Well, I've done everything I read to set up my Blu Tank II, bought prepaid service from H2O & still getting "no service". Anyone have some insight on what I'm doing wrong?
I called H2O for support, the guy couldn't help me after 15+ mins, said someone would call me back in 10-15 mins, never received that call back. This is getting so frustrating.
Счет 0
Добавьте свой ответ
Carol Dankelman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 18
За всё время: 1,409
