Руководства по ремонту и поддержка планшетов производства компании Zeki. На задней панели планшетов Zeki по центру заглавными буквами написано название «Zeki».
problem with storage/SD card
I have an external SD card, i t won't allow me to add any of my apps. My tablet says storage space is running out, what is going on?
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
When you go to move the apps, is there an option to do so or is it greyed out, (move to SD Card)?
If there is no option to do so or it is greyed out, it is because the developer of the app has not set the "permission" flag which enables it to be moved. This could either be by omission or design.
Also if the apps that you wish to move came pre-loaded with the tablet, they are part of the system and can only be moved if you root the tablet.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
There is the option to move to SD card, but when I try to move it ,it reads no storage space. I even tried a new card and got the same results.
из
Hi,
Not sure if you have this setting but go to Settings > Storage and see if the SD card appears as a storage option and how much storage space is available.
Have you tried inserting the card into a card reader connected to a PC and see what is stored on it (if anything)?
If nothing is stored try formatting the card again and then re inserting it into the tablet.
из
Either it's full of data, or hasn't been properly formatted.
Счет 0
Добавьте свой ответ
jetherton1949 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 16
За все время: 1,535
