8,9-дюймовый планшет, совместно разработанный Google и HTC. Впервые выпущен в ноябре 2014 года, работает под управлением Android 5.0 Lollipop.
Sudden refusal to charge
After a couple of years of 'no problem' day to day' use, my Nexus 9 has suddenly died. I don't think think it was 'mid use death' , it hasn't been dropped etc and is in excellent condition.
I suspect that it ran out of battery and now is refusing to charge. I'm not even getting the white flash when in a very low battery state.
Before I buy a replacement battery, does anyone have any suggestions?
Ive tried every combination of button pressing to boot to different states, bit I suspect it's a batter issue.
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Выбранное решение
I have no suggestions except replace your battery. I'm pretty sure that your battery is completely dead.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Just a quick update, my new battery arrived today, fitted it and booted first time.
из
Yay!!! Glad your phone is back to working condition :)
из
Phone? The Nexus 9 isn't a phone, it's a tablet. I don't even think it has 3G/4G capabilities. What do you mean?
из
David. Just a question. Where did you find a Nexus 9 battery? It is a nightmare to find....
из
Наиболее полезный ответ
@davidtjackson you may want to check that your chargers working . Check your cable try it with another one, check the port that theres no lint or dirt preventing the cable from connecting properly . If you have access to another charger try it . You may also want to reseat the battery as it can sometimes just need to make a new connection to work again and recharge. These are a few things Id try before buying a new battery. Hope this helps
Счет 3
Thanks both,
I've managed to rule out it being a faulty cable. I've found a replacement battery - so hopefully it'll be that. I'd have expected it to last longer than a couple of years, but I suppose these things just die every so often.
Счет 0
1 Комментарий:
Glad to help. And sadly yes, rechargeables only have so many charges in their lifetime.
из
Добавьте свой ответ
David Jackson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 23
За все время: 557
