Руководства по ремонту и поддержке зеркальной камеры EOS 70D, выпущенной Canon в 2013 году. Модель можно определить по номеру DS126411.
Sd card reader not working
Man sd card got stuck in the camera. When it got pulled out a little piece broke now it says the sd card is locked even though its not.
Это хороший вопрос?
Счет 0
1 Комментарий
Nothing wrong with my card. My card reader of the camera not reading cards
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Hi,
A little piece from where, the SD Card or the camera?
Most SD Cards have a sliding lock switch. Is this missing from the SD card?
(click on image to enlarge for better viewing).
If so replace the SD Card.
If the part is from the camera, as I cannot locate a service manual online, here is a link that shows how to replace the LCD screen in the camera. Hopefully it contains enough information for you, about opening the camera, so that access to the card reader is possible for it to be replaced.
https://www.youtube.com/watch?v=N4jD6_6R...
Here is a link to some suppliers of the card reader (if that is the problem). It is not a recommendation to use any of the sellers. It is just shown to give an idea of the cost of the part.
http://www.ebay.ca/sch/Replacement-Parts...
To replace the part, you will need the requisite SMD (Surface Mounted Device) soldering skills and tools. It may be cheaper in the long term to take it to a reputable, professional camera repair service and ask for a quote for a repair.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Christian Morales буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 31
За все время: 2,007
