Модель A1181: процессор Core 2 Duo с частотой 1,83; 2; 2,1; 2,13; 2,16; 2,2 или 2,4 ГГц
Heat extractor instead of DVD Optical Drive
Is posible to remove the dvd optica drive to
put a heat extractor or any other cooling system.
I want to reduce the macbook temperature, I'm most of the time in a Library watching educational videos on youtube.
And also running parallels .
And it makes the cpu to 77º , fans 6200 rpm so it turns too noisy .
For me would be perfect to replace the optical drive with a Fan ,extractor any or cooling system , capable to get the heat out through the slot where normally we insert the dvd. In a silent way of course.
It is posible or I'm just dreaming ?
Macbook 2007 2.2ghz (santa rosa) A1181 4gb ram 500gb hd
Это хороший вопрос?
Счет 2
1 Комментарий
I am having the same issues with my MBP, and I also was thinking to remove optical drive and install additional heatsink. Have you had any success?
из
Добавить комментарий
2 Ответов
Выбранное решение
It could
be done, but this is not actually a "repair" question.
Removing the Optical drive and the felt from the slot is no problem, neither is finding a fan or two to epoxy in place. The trick will be in powering them on.
I would opt for low speed fans that are either on all the time or triggered through a switch/button run out the disk slot.
I say switched because unless you have a way to power them off they'll drain your battery pretty quickly. I should think a software switch would be pretty complicated.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
I understand , I need a Fan with its own temperature sensor , so itself can determine when to stop or run faster. I don't know if exists that kind of "intelligent" fans. And if it's worth for the price.
из
I agree with Meyer you shouldn't really need to do this.
из
If you're having heat problems, I would replace the thermal paste and clean the vents and fans out when doing it. It's just not necessary to install such a heat sink.
Счет 3
1 Комментарий:
Ok I did it , Here are the photos http://picasaweb.google.com/fernandez.Al...
As you can se , there was a lot of dust !
Now its cooler ,
Chrome surfing:
8% cpu -> 45º -> 1600rpm
But running parallels :
System cpu usage : 50% (parallels) + 4% cpu user usage -> 72º ->6200 rpm (heatsink 1:54º heatsink2:53º
So, as for my normal use of mac It's so easy to get temperatures over 70 , (if I open youtube + paralleles I get 80º ) , I still need a solution.
Fan at 6200 , its not something broke mechanical noise, it's working well but it's noisy
Now that I already know how to open the macbook and remove the fan ,
I thinking to search and buy a more efficient fan (if it exists) to replace the original one .
Do you know if it exists ?
And do you thinks this ratios are normal ?
54%-60% cpu = 70º 78º = 6000 - 6200 rpm
70- 80% cpu = 80º = 6200 rpm
thanks
из
Добавьте свой ответ
Fons буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За все время: 3,435
