Sharp EL-531X — это научный калькулятор, выпускаемый компанией Sharp.
How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
Это хороший вопрос?
Счет 2
1 Комментарий
The calculator will display 1 no matter with the battery or not.
It stop working.
из
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
Reset
(click on images to enlarge for better viewing)
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
из
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
Счет 0
Добавьте свой ответ
fahimakhan2 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 45
За все время: 5,325
