Эта итерация серии электронных книг Amazon Kindle Paperwhite была выпущена 30 июня 2015 года. Kindle Paperwhite 3-го поколения представляет собой 6-дюймовый планшет для чтения с дисплеем 300 PPI и поддержкой Wi-Fi. Номер модели — DP75SDI.
Frozen unresponsive screen. Can it be repaired?
Hi!
I have a Kindle Paperwhite, 6" High Resolution Display (300 ppi) with Built-in Light, Wi-Fi - bought in October 2015.
Kept well, it hasn't fallen down, nothing untoward. Stopped working. The screen had an erratic display for a while, and has now stopped responding.
Can anyone help?
Это хороший вопрос?
Счет 4
1 Комментарий
I am having the same problem, could you find a solution for this? Please let me know.
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I had this problem with an e-reader and it turned out that it quit charging. After placing the e-reader on a new charger it started working again. The models we use in our school are all nooks but this may help you out too.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Hey! Thank you so much. But this one is charging. No problems with that. Just that the screen gave an erratic display and then stopped responding. I am trying to understand if it is a screen or motherboard issue. Will try and fix it accordingly.
из
Did you find a solution to this? I am having a similar problem
Счет 0
2 Комментариев:
... me too!!!
из
@skeeve205 could you please let me know if you found a solution for this?
из
Try tapping (or knocking with your nail) in the bottom right corner of the front. (Edit: you can also try bringing a magnet to that corner and bringing it away)
If it responds, then I have a workaround for this, that I’ll publish as a “technique” guide within the next few days. (EDIT: here it is!) The only problem with that guide is that it will no longer respond when opening/closing the cover
Счет 0
Добавьте свой ответ
Anamika Das буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 24
За всё время: 5,232
