Информация по ремонту и руководства по разборке ноутбуков производства Haier.
Some keys of keyboard NOT Working?
Some keys of keyboard NOT Working ??Like N,space,ALT,B,C.ENTER key .How can i repair..If it cannot be repaired and need to changed keyboard of my haier laptop ?Which keyboard model can fit into this laptop.Thanks
Это хороший вопрос?
Счет 14
15 Комментариев
faraz0920 what model is your Haier Laptop
из
Haier YB11 PM Nawaz Shareef
из
Hello,
We have an laptop y 11c ,its keyboard has been stop functioning because of few drops of water have spilled on it, i want to change its keyboard so that it could function like earliar..
из
i have new hair laptop of prime minister and some keys of keyboard not working now what i do bro
из
If it's new, take it back to where you bought it.
из
Показать ещё 10 комментариев
Добавить комментарий
4 Ответов
Выбранное решение
I don't know this make of laptop, but for most, swapping the keyboard is fairly straightforward. You may have to remove a bezel between the keyboard and the hinge to gain access to the required screws, or you may have to remove one or more screws from the back, or indeed the keyboard may just clip in place. Then you just need to be a bit careful in releasing the ribbon or ribbons connecting the keyboard to the motherboard. You probably wouldn't be able to fix the troublesome keys in your existing keyboard.
You will need a replacement keyboard for the exact same model, and make sure it's the right language, but hopefully you can find one on eBay.
Был ли этот ответ полезен?
Счет 2
Наиболее полезный ответ
Guys, for Haier y11c, the best option is to disable the keyboard and use an external one. The best method I’d recommend is to disable the keyboard hardware by opening up the laptop and detaching the ribbon cable. This way you will not have to put up with any funky software. You could try disabling it through a software called KeyTweak.
Other than that, replacing it might cost you around 4-5k PKR since the keyboard is chiclet-style and you will have to replace the whole panel. This is just not worth it.
Счет 3
1 Комментарий:
In my case, the key tweak is working very well. At least there's no need for an external keyboard now, although my first two rows are dead. I have replaced some necessary keys and also touch keyboard as well helping me out.
из
The keyboard is faulty and needs to be replaced to solve it.
Счет 1
Visit following link .
https://youtu.be/AZS4osYJ_C8
Счет 1
1 Комментарий:
Irrevent solution.
из
Добавьте свой ответ
faraz0920 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 14
За последние 30 дней: 70
За всё время: 17,297
