Fluorescent lights dim and flashing
I have a fluorescent light fixture that uses two 40-watt 4' long tubes. It has recently started acting strange. When first turned on, it works fine for a minute or two, then one of the tubes becomes dim and the other becomes dim and flashing. It's not the tubes, as I've replaced those and nothing changed. Someone suggested it might be the ballast. I'm not exactly sure exactly how old the fixture is, but I'd guess it's at least 10 years old and has been used daily for that entire time. Is the problem caused by the ballast, and if so is that something that can be changed, or should I just buy a new fixture?
Это хороший вопрос?
5 Комментариев
An update: I was able to get a replacement ballast at Home Depot. The bad news is the ballast was $18.49, only $1.50 less that a whole new fixture. It took about half an hour to install the replacement ballast. The replacement was successful and the lights are working great now. In my fixture there were eight 18 gauge wires that you have to cut and then attach to the new ballast. I used wire nuts to connect the wires, so it'll be a little easier to replace the ballast again in the future.
из Luke Soules Поделиться
That is the normal end-of-life behavior of a fluorescent tube.
You probably ruined the ballast by letting it continue to run while it was flashing.
If the ballast came with the lamp clips on the end of the wires, it is easier to just change out the clips too.
из midimagic Поделиться
We've had problems for years we are fluorescent lights dimming or not coming on at times of high humidity. Sometimes I can get them on by flipping the light switch off and on several times and out of the three maybe one will only come on. This is been going on for several years and just recently the lights are getting harder and harder to turn on.
из Tim Houser Поделиться
The good news is LED lighting is getting cheap fast. You may want to look here. https://www.instructables.com/howto/LED+...
из Ricardo Furioso Поделиться
I had the same problem. I could not go another way because I needed the fluorescent tube to work for a UV light for my pond. That was the only way to get the light to filter my water. With LED not doing the same job. I could not go for a bulky electronic balast because of the space of a sealable unit. So I had to get this one sorted out.
What solved my problem…
I found that this light needed a 4 micro farad capacitor with double the supply voltage of the mains connected across the Live and Neutral wire. The light flashed a few times and then can on to its full brightness. Be sure to use a ac capacitor normally comes with the light fixtures for your country and the balast wil have a drawing on it where to wire it in.
Marking s wil show the starters position and the —| |— wil indicate the capacitor position.
из Juan Engelbrecht Поделиться
