Lenovo IdeaPad 300-17ISK — это 17-дюймовый ноутбук, выпущенный в октябре 2016 года. Номер модели: 80QH008MUS.
Fan Replacement without heatsink
Hi There, I was wondering if there will be any issues replacing the fan with one of same size but no (what I believe to be) heat sink? Whatever the Copper attachment is. The fan bearing went bad so now it shakes and makes a lot of noise when I use my laptop which is quite annoying, I deal with it by using headphones but can't really take it out because of how loud it is. If I can't replace the fan with aftermarket fans that don't have the copper attachment is there anywhere I can purchase the same fan used for this laptop?
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
Here is a link to the service manual for your IdeaPad.
Scroll to p.55 to view the necessary pre-requisite steps and then the procedure to remove the fan/heatsink assembly.
Scroll to p.87 to view the parts numbers (#12&13) for the fan and heat sink. Search online using the appropriate part number only to find suppliers of the part that suit you.
Был ли этот ответ полезен?
Счет 2
this is what you need. https://www.ebay.co.uk/i/192312127707?ch...
Счет 1
Добавьте свой ответ
Kevin Nguyen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 763
