Руководства по ремонту, разборке и диагностике Apple iPad 5-го поколения с Wi-Fi, доступного с 32 или 128 ГБ встроенной памяти. Выпущен в марте 2017 года. Идентифицируется по номеру модели A1822. Оснащен 9,7-дюймовым дисплеем Retina и 64-битным процессором A9.
Replaced Screen - Home Button Works But Not To Wake?
Hi All,
Just replaced a digitizer on an iPad 5 (2017 model). All went fine, was very careful.
Home Button assembly hasn't been damaged ..... but now the home button will not wake the iPad from sleep?
If I wake up the iPad from sleep using the power button, the home button works 100% , as both a button and the Touch ID - 100% functionality.
Any ideas why it won't work to wake the iPad up though?
Thanks
Alex
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
My thoughts point towards the magnet sensor that senses a magnet inside a case, telling the iPad to wake up if you uncover the screen. I never checked the schematics for that but considering the symptoms of your issue i guess they share the same circuit.
This sensor is soldered on and should be removed and replaced to the new assembly with a heat gun or something like that.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
Thanks for that, have you got any info as to the location of this sensor? I had a quick look and there doesn't seem to be anything obviously different between the new and old assemblies?
Already moved the entire home button assembly / bracket / ribbon etc.
из
Could be one similar to this: https://www.dropbox.com/s/gi7vmhfwvu9wtd...
This is on an Air2, so not sure. It is covered by some black tape
из
Thanks for that, upon further inspection the home button doesn't appear to be working as a button AT ALL!?!?!?!
It does still physically "click" and Touch ID works 100% - just not the button function?
из
Добавьте свой ответ
Alex S буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 13
За все время: 1,079
