Серия Signet была топовой линейкой 35-мм камер американского производства компании Kodak в 1950-х годах. Это одна из двух моделей Signet, оснащенных дальномером, и единственная, корпус которой изготовлен не преимущественно из пластика.
double superimposed rangefinder patches problem
When view through viewfinder on kodak signet 35 , the rangefinder patch appear from 2 triangle 70% superimposed but slightly shifted horizontally on left side.I could not discern what would cause one triangle to split into two, though I suspect it's a a misalignment. What area should I be inspecting?.I wait for yours ideas.Thanks.
Это хороший вопрос?
Счет 1
1 Комментарий
Добавить комментарий
1 ответ
Выбранное решение
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Замена светоделителя Kodak Signet 35. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
из
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
из
Thank you very much
из
Добавьте свой ответ
Florentin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 784
