Информация по ремонту и устранению неисправностей ноутбука Dell Alienware M17x R2, второй версии игрового ноутбука M17x от Dell.
How do I replace the thermal paste on the gpu.
I took my gpu out of my pc but I don't know how to safely get to the compound.
Update (02/12/2018)
this is the gpu I need to repaste
Update (02/12/2018)
gpu
Это хороший вопрос?
Счет 1
1 Комментарий
@samadam It appears all you need to do is unscrew the screws around the heatsink that attach to the clamp on the other side. It looks like a philips.
I've updated my answer.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
This may be what you're looking for: Нанесение термопасты
Update (02/12/2018)
Unscrew these screws:
And it should come off. Be sure to clean and reapply thermal paste to mating surfaces when done.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Not quite what im looking for ,thank you. Is there a way for me too send you a picture of my gpu. It has a x like clamp on it that I assume the paste is under but I don't know how to safely remove it. It kinda looks like the clamp on a Xbox one gpu.
из
@samadam, use this: document
Pages 85 and up I believe.
из
Flat head screwdriver if it's like the Xbox. Then u can get thermal paste cleaner and thermal paste online. A plastic razor blade (similar to the red kind used on lcd displays) should easily remove the paste.
Счет 0
Добавьте свой ответ
Samadam буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 857
