Brother MFC-440CN — это многофункциональный цветной струйный принтер с лотком для прямой подачи фотобумаги, впервые представленный в 2001 году.
Clear "paper jam" message
On a MFC-4420DW I'm attempting to print business cards on Avery stock through the rear, single sheet feed tray. Data transfer from PC is very slow, and when printing begins only the first quarter of image prints and sheet exits printer. Thereafter I get a Paper Jam message. I have followed the "clear paper jam" instructions several times, referred to online instructions, used a letter-sized sheet of glossy photo paper for the "remove paper scraps" function, but printer does not grab the sheet. I have closely searched the inside of the printer for scraps and can't find a thing. How can I clear the error message so I can use my printer again?! Frustrated!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi,
Have you set the printer preference Media Type in the computer, to 'other photo paper' to allow for the thicker paper that you are using? You didn't say.
if this doesn't work in the Paper Size preference you can specify the 'thickness' of the paper that you are using.
What OS is installed in the computer connected to the printer?
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
katiepricega буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 755
