How to fix my dpad?
all dpad directions seemed to work fine, until the down button stopped working (left,right and up are fine)
Это хороший вопрос?
Это хороший вопрос?
Mathew--There are small tabs on the dpad, it is possible the one on the bottom has broken off causing a miss alignment with the botton on the board. I would suggest using the repair guide to open it up and see if this is the case. If so you can purchase dpads rather cheaply. Hope this helps.
Был ли этот ответ полезен?
The D-PAD buttons on the Xbox One controller are small metal domes. Sometimes, they worn out and need to be replace. The good news it that they are help in place by a sticker and are pretty cheap and easy to replace.
This video should also help you out to do the repair and to install the new buttons : https://youtu.be/qJf9KZ0H1UQ
За последние 24 часов: 1
За последние 7 дней: 19
За последние 30 дней: 68
За все время: 14,352
