Asus ROG Strix GL702VM-BHI7N09 — это игровой компьютер, выпущенный компанией Asus в январе 2017 года.
Replace broken internal speakers?
I bought new parts for the internal speakers, but I'm not sure how to install them. I have updated the audio drivers several times previously but to no avail. My guess is an acquaintance of mine accidentally blown the speakers resulting the problem.
Update (04/01/2018)
The audio worked fine when I was using my earphones.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi,
Is the audio OK when using headphones?
If not then perhaps the speakers are not the problem and you may have a problem with the audio controller.
As it is most probably mounted on the motherboard, the simple way to get around the problem would be to use a USB sound card.
Update (04/01/2018)
Hi,
Just covering all bases. ;-)
Cannot find a speaker replacement guide for your laptop but here is a link to the ifixit Замена жесткого диска Asus ROG Strix GL702VM-BHI7N09 guide, which should get you access to the motherboard. Hopefully it will be easy to see how to replace the speakers once you have got that far.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Faiz Zailani буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 1,077
