battery discharge very fast
When i charge my phone and complete charging then when i started to use my phone
it is immediately shut down
Это хороший вопрос?
Это хороший вопрос?
@maxnet ….either one of two thing is happening. your phone goes into a charging state but is not actually supplying voltage to your battery or your battery has dead cells and is not actually taking a charge. you can test which one it is by verifying the voltage is travelling from your charging port to your battery terminal. if the voltage is there, change your battery. if not, start troubleshooting your charging port circuit. here is some basic troubleshooting guides for your phone:
you can also test your battery to see if its short or taking a charge by reading its internal voltage at different intervals while charging.
Методика — проверка аккумулятора
hope this helps. post back here for any further assistance
Был ли этот ответ полезен?
Thank you very much. For me it was the battery. As I swapped it, it works again.
good to hear. good job.
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 15
За все время: 311
1 Комментарий
Hi mfshahri, could you solve your problem?
из Max
