Samsung Galaxy Note 4 — это сотовый смартфон, выпущенный в октябре 2014 года. Номер модели Galaxy Note 4 — SM-N910, а для американских вариантов — SM-N910A, SM-N910T, SM-N910V или SM-N910R4.
Microphone and/or speaker problem
When I am talking on phone with speaker OFF I am told I cannot be heard, that my voice is breaking up. When I have speaker ON this problem does not exist. Please help!
Это хороший вопрос?
Счет 3
Добавить комментарий
1 ответ
Выбранное решение
Hi @louisianagal ,
There are two microphones in your phone. One for "normal" calls and the other is used when the phone is in loudspeaker or 'hands free' mode
There may be a problem with the phone's internal microphone or perhaps the voice inlet hole located at the bottom of the phone may be blocked by lint etc.
To check the latter possibility, use a strong light and a magnifying glass to check if the hole is blocked (bottom edge of phone).
If it appears to be (or even if you can't tell) use a vacuum cleaner to try and clear the obstruction. DO NOT use a pin or probe as it may damage the microphone which is directly behind the hole.
If this did not resolve the problem then the phone needs to be opened and the microphone checked to see if it is a loose connection or a faulty microphone.
Here is a link to the ifixit Замена дочерней платы порта Micro-USB в Samsung Galaxy Note 4 guide which should be of some help.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Marion Davis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 18
За все время: 19,248
