Nintendo Switch — это портативная игровая консоль, в которую можно играть как на телевизоре через док-станцию, так и на ходу. Выпущена 3 марта 2017 года.
Strip screws? How to fix?
Hi i screwup my side console, by stripping one of the screws. ( i used a y00 instead of a y000). Rubber band and super glue didnt work. To remove glue i use a drill bit (1mm), now there is a counter sunk hole. Ideas?
Это хороший вопрос?
Счет 8
Добавить комментарий
5 Ответов
Выбранное решение
Sounds like you already have drilled a hole there so I would just get the next biggest drill bit and drill it more. You might even need to use the next biggest bit after that. Once you drill the head off then you can usually take it apart more until you can get to the screw and use pliers to turn it out.
Hope this makes sense.
Был ли этот ответ полезен?
Счет 7
Try this
Precision Screw Extractor Set
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm. Изображение
Товар
$24.99
Счет 3
Welp.. Y00 is correct you might have presed a lot. Y00 works for me
Счет 1
So how was this problem solved? I have the same situation. Please help.
Счет 1
Needle nose pliers is what worked for me
Счет 0
Добавьте свой ответ
jonathan ambrose буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 43
За все время: 34,555
