Официально называемая Chevrolet C/K, серия C/K представляет собой линейку грузовых автомобилей, производимых General Motors и продаваемых под брендами Chevrolet и GMC. Серия C/K включает пикапы, среднетоннажные и тяжелые грузовики.
Very difficult to move in reverse gear.
The truck will shift through all forward gears just fine without any trouble, but when I put it into reverse I have to give it probably around 3000 rpm to move at all. Trans needs serviced bad. Just wondering if that's my issue or if I have something more to worry about. 1992 Chevy c1500 5.7L automatic 4x2.
Это хороший вопрос?
Счет 0
2 Комментариев:
Once in a while I can get lucky and get it in reverse but I can't count on it
из
If I can get it in reverse it will not move and occasionally it's almost like it's stuck in gear
из
Добавить комментарий
1 ответ
If your trans needs a service bad, it might be failing. I'm not sure how many miles you have and how you maintain the car, but by the sound of it, it might be slipping in reverse, so you would need to get a new trans, or get your old one rebuilt. Both are expensive unless you can find one in a junkyard for a good price.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
It is probably the transmission/torque converter. I had the same problem with a prior car...it would lose power in reverse. Quickly shifting into neutral and back to reverse made it work momentarily.
из
Добавьте свой ответ
Cole Custer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 1,313
