Руководства по ремонту и разборке принтеров Samsung.
Reset WPS Pin Manually
A hacker was able to access the WPS pin for my Samsung XPress C1860FW, connect it to a remote network and denied me permissions to reconnect and print either offline or online. Now, I cannot access the LDC touch display because I do not have permission. I paid a network specialist but he was unable to reset the WPS pin. I cannot do that without access to the LDC display. Suggestions?
Это хороший вопрос?
Счет 1
1 Комментарий:
can you help with this
из Поделиться
Добавить комментарий
2 Ответов
Hi Jennie,
You can try the master reset procedure:
1. Hold 1,2,3 on the front panel simultaneously.
2. Enter password 1934 and select OK.
3. Select "Test Routine".
4. Select "Other".
5. Select "Memory Clear".
6. Select your country, and press "Start".
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
I tried this and it says not available now. I need the WPS pin for the printer.
из Поделиться
Where do I find it?
из Поделиться
1) On the selection wheel, press the “Menu" icon button
2) On the numeric keypad, enter "# 1 9 3 4"
3) Press the “Menu" icon button again. The printer displays "Tech Mode".
4) On the selection wheel, press the "OK" button
Your printer is now in Tech Mode. Within this menu you can reset the printer back to factory settings a/o reset counters, and access other printer default settings.
Счет 0
Добавьте свой ответ
Jennie Johnson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 30
За все время: 1,926
