Changing charging socket :galaxy j7 2017
How Can I change the charging socket of the j7 2017? And ehrte do i find the Parts?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @ohmann ,
Here’s a link to a video that shows the teardown of a galaxy J7 2017 phone.
This is useful as it shows how to remove the motherboard so that access to the charge port is possible.
At 9:00 minutes into the video the motherboard is shown being removed from the phone.
As the port is an SMD (surface mounted device) type connector, you’ll need SMD soldering tools and expertise to effect a replacement of the connector
Charging port connectors are available online. Just search for Galaxy J7 2017 charge port part to get results.
Here’s a link to just one supplier. It is not a recommendation to use them. It is shown to give an idea of what it looks like and what the cost of the part is. There are other suppliers online that may suit you better.
SMD soldering is not for novices. You can cause more damage than what you had before you started if you don’t know what you’re doing.
If you find this too daunting, contact a reputable, professional mobile phone repair service and ask for a quote to repair the port. You already know the cost of the part ;-)
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
Omid Asalat буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 2,564
