Руководства по ремонту и обслуживанию сушилок для одежды.
LOC Code on my dryer
I have a Affinity Frigidaire front load dryer. LOC is preventing it from running. Any solutions?
Это хороший вопрос?
Счет 1
1 Комментарий
thank you so much. The clothes were piling up.
из
Добавить комментарий
4 Ответов
Выбранное решение
juliet.crawford760  start of with this information
“Dryer Features
Control Lock
To avoid having someone accidentally start or stop the dryer, press Options and Select at the same time and hold for 10 seconds. “LOC” will be displayed. To remove the control lock, press Options and Select again.
Был ли этот ответ полезен?
Счет 6
1 Комментарий:
This worked!!!!!! Frigidaire affinity dryer and this worked! Thank you
из
opened the door while dryer was still going and got the LOC displayed - to clear it held the options and select at same time until it beeped - hope this helps someone
Счет 1
1 Комментарий:
My dryer is an older dryer be but it still worked! Thanks!
из
Westinghouse easycare 500 washing machine has LOC display
I have tried holding in loc button and start for 10 second s and also turning the machine off at the power source with no response
What else can I do
Please!
Счет 0
2 Комментариев:
Not this model, but same problem.
из
@suelong92375
What is the make and model number of your washing machine or dryer?
из
Hi @janellemorris
Bit late but for anyone else having the same problem to activate/deactivate the child lock function, press and hold the “Prewash” touchpad for about 2 seconds until the display shows either L OC or u nL
Счет 0
Добавьте свой ответ
juliet.crawford760 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 61
За всё время: 7,379
