Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
No Battery Health Stats
After installing the replacement battery the battery health stats do not populate. Prior to ordering the replacement it was clear the original battery was done for. So I order the replacement and everything went fairly smooth. Let the battery drain (below 10% as I got the pop up alert). I think proceeded to charge the battery to 100% uninterrupted.
My problem - battery health still reads the status service. Even after doing a full reset on the phone it still says service. With exception to one random reboot the phone is running fine. A third party app seems to confirm the battery capacity is going to a full charge. So as far as I can tell everything should be fine. It did seem like the phone got warmer then I’m used to with the new battery, but then it was always in a case.
Any clue why apples Battery Health reading would say I need to service the battery still? Is there an extra step for reseting that?
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Выбранное решение
The battery health feature in iOS is a bit of a hit and miss. It works one some batteries and it doesn’t work on other batteries.
This is particularly more common when it comes to aftermarket replacement batteries. There isn’t a way to get it working other than trying another battery but in my opinion I would leave it as it is.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
I got this too and my battery only about week old
из
Наиболее полезный ответ
Apple did remove this feature for replacement batteries, its stupid but that is the way it is, my iphone 6s+ got a battery from apple and its reading the percentage just fine, but my friend got a battery for his 6s from some website and the health meter isn’t working.
Счет 1
Добавьте свой ответ
Ross Brayton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 25
За всё время: 12,372
