Выпущен в марте 2016 года. Модель SM-G891A.
LCD replacement screen only
I'm trying to find a replacement LCD screen only. I have the digitizer fog with polarizer, loca, and a new front glass. But need the LCD screen and how do I combine the LCD and digitizer together?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
If I’m reading you correctly, you’ve purchased most of the separate parts of the display assembly and you’re looking for (a) a source for the LCD and (b) instructions on how to assemble it?
I think you’re confused. The parts you have are intended for professional screen assemblers/refurbishers, not DIY’ers, and require speciality tools and equipment to put together. When complete, the digitizer and screen are laminated together as a single unit. Here’s an example of a screen being assembled and laminated together. It’s not really something that a casual end-user can do at his dining room table, like putting a screen protector on a phone.
Some phones have separate digitizers and screens — you can replace the digitizer/glass independently of the screen — but the S7 Active is not one of those. You’d be best off buying a replacement unit — the screen and digitizer together. It will take a lot less time and effort, and you won’t have to invest in an expensive tools and equipment (and don’t forget about training/practice).
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Sorry to bump this, but if I were to open the phone up, would I need new adhesive on the rear of the LCD panel? Or would this adhesive re-stick given some heat and time to cool down?
из Поделиться
Добавьте свой ответ
Michael Shep буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 18
За все время: 468
