Компактный компьютер (SFF) Dell, выпущенный в 2002 году. Покупатели могли выбрать процессор Celeron или Pentium 4. Набор портов расширения включает: 1 разъем AGP (опционально), 1 разъем PCI на материнской плате и еще 2 разъема на райзер-карте PCI.
Several questions about computer.
The round plug ins with different colors in the back of the desktop,can they be used as av plug ins to my smart tv?
Was this model built with wireless.
Can i reinstall software to use wireless.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @robglaub ,
The blue connector is Audio Line In so you could attach the TV’s analogue audio out (if it has one) to it to record audio from the TV.
The green connector is the Audio Line Out so unless the TV has a vga port (sometimes called PC-In) to view the PC video (use the TV as the computer monitor) along with the audio, it would be impractical to connect it to the TV’s analogue Audio In just to hear the computer audio
The pink connector is for a microphone input. The signal levels from a TV analogue audio out would be too high and could damage it or at best give distorted sounds
According to the specifications the computer has no inbuilt wireless capability, but you could install a WiFi card in a vacant PCI slot to give the computer WiFi capability or perhaps as pci cards are hard to find (nowadays most are pci-e which won’t work in a pci slot) it may be better to use a USB WiFi dongle - info only to obtain WiFi capability
If you do decide that you want to try and use a pci card as your computer has a SFF (small form factor) you need to search online for a low profile PCI (Not PCI-Express) WiFi card.
What are you trying to do by connecting the computer to the TV?
If you’re trying to turn it into a media centre there is a lot of information online on how to do this ;-)
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
RobertG буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 27
За все время: 314
