Третье поколение умных часов Apple с опциональной поддержкой сотовой связи, выпущенное 22 сентября 2017 года.
Water damaged Apple Watch
I went out for a run, took my watch off because it died and I put it in my pants pocket. I washed those pants and now the screen is cracked and has water damage. It will not turn on. I’ve tried everything. Is there any possibility that my watch could be fixed and if so what would it cost? It’s a Series 3 I believe.
Это хороший вопрос?
Счет 5
3 Комментариев
My Apple Watch died while I was inside the Pool and now is full of water inside how would I fix this ?
из
Hi my Apple Watch died too but I washed my hands my screen was already cracked and it stopped there got soap and water on the display and if I’m super unlucky it will be in the battery or logic board too I want to repair it by myself but idk what is broken or what to do someone I need advise and some thoughts if it’s riviveable
из
Same thing happen to my Apple Watch. Did you have to replace everything or just a few different parts?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If you believe it has water damage, you must disassemble and clean it using at least 91% isopropyl alcohol, (you can use this Разборка Apple Watch Series 3 to do that) make sure to scrub everything with a toothbrush.
more details on water damage can be found here: Electronics Water Damage
It is a tough repair, but as long as you follow the instructions you should be fine.
Был ли этот ответ полезен?
Счет 9
1 Комментарий:
I went to the beach and I didn’t lock my Apple Watch and now the brightness is red and I can barely see or know where things are, hoe can I fix it?
из
I was scuba diving and found a Apple Watch and I want to see if it can be fixed
Счет 0
Добавьте свой ответ
Breniecia Camphor буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 48
За все время: 38,120
