Информация по ремонту контроллера Nintendo 64, номер модели NUS-005. Этот контроллер был выпущен в 1996 году для игровой консоли Nintendo 64.
How do I remove the plug?
One of my controllers suddenly stopped working in the middle of a Mario cart race.
I finished the race with the other controller so the port is fine.
Buttons/joystick don't do anything and plugging into port 1 shows no controller detected.
Not sure how this could happen suddenly with no drops or yanks just dead.
Tried to test the wires in the cable and the white /middle wire seems to show no conntenuity.
How do I remove the plug though?
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Выбранное решение
For anyone finding this via searching
you need
2x 3mm Terminal Removable Tool
1x 2mm Terminal Removable Tool
Per this youtube video
https://www.youtube.com/watch?v=EPJH0JcL...
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thank you - exactly what I was looking to confirm.
из
Do you mean the wire? If so, it’s connected to the board by a 4-pin poke in connector on the back of the board. The only disassembly step required to access it is removing the back plate. If you do intend to replace it, you will need another controller to get a cable from, most likely.
Счет 0
2 Комментариев:
No I wanted to remove the plug from the wire or open it to check the internal wiring there.
I was wondering if there was a good method to do that without damaging it.
It looks like there is at least 1 maybe 3 tiny clips but my attempts so far have only started to damage the plastic.
из
looking at mine it looks like the plastic on the plug end is fused together pretty well. I don't know that it's possible to disassemble it without damage.
из
Thanks for the amazing link to the video.
I actually ended up replacing the whole cord.
Found it on amazon. All though it's not as flexible and is starting to fall apart with hardly any use.
Счет 0
Добавьте свой ответ
Darren Jones буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 21
За последние 30 дней: 61
За все время: 3,309
