a7R II (номер модели ILCE‑7RM2) — это выпущенная в 2015 году полнокадровая беззеркальная камера Sony со сменными объективами.
Immediately after turning camera on - camera error..
Immediately after turning it on, it clicks up and down the shutter on the display and in the viewfinder a camera error is displayed. Turn off the power then turn it on. Tell me what could be the problem. Can I diagnose the camera on my own? Tried to shake the camera a little does not help
Это хороший вопрос?
Счет 0
2 Комментариев:
any error codes? what is the exact message? do you have a lens on the camera?
из Поделиться
No codes. message "Camera error.Turn power off than on." no matter with lens on camera or without.
This is almost a new camera. maybe 100 shots. Owner did't use it for a couple of years . Then he decided to sell it. everything was okay .he checked it. went to the meeting with the buyer on the bike. Turned on- there was this error.If a memory card is inserted, the red light flashes for a few moments.
recharging the battery from power bank works.
I'm not an expert, but it looks like the motherboard is working.
Inside there is a small ML621 Rechargeable 3V battery . May be dead.
из Поделиться
Добавить комментарий
2 Ответов
Shutter is stuck it seems. Follow this sony guide: https://us.community.sony.com/s/question...
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
tried. didn't help.the sensor is not skewed like on youtube video,moves as if normal
из Поделиться
Try to reset camera to factory default If possible. Remove battery and then press and hold power button for 10 second and then reinsert battery.
Different camera has different way to reset check manual.
Счет 0
1 Комментарий:
unfortunately does not help. Nothing happens
из Поделиться
Добавьте свой ответ
Yuri Mironov буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 16
За последние 30 дней: 42
За все время: 2,064
