Scotch TL901 — это термоламинатор для ламинирования плоских материалов шириной до девяти дюймов. Устройство поддерживает два температурных режима и позволяет использовать пакеты для ламинирования толщиной до пяти мил.
Scotch TL902 laminator assembly instructions
I recently got the scotch laminator tl902..the sheet was jammed so,I opened the machine and removed the jam..But, now unable to assemble it back..Any step by step instructions with pictures would be great help
Это хороший вопрос?
Счет 1
2 Комментариев
How can I close the input tray on my laminator tl902 when finished and want to put it away?
из
How do you get the insert tray out in the position needed to insert
laminating sheets?
из
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
Here’s a link to the ifixit Разборка ламинатора Scotch TL901 guide, which may be of some help
You may be able to reverse the procedure to re-assemble the laminator.
Research online indicates that the only differences between the TL 901 and the TL 902 is that the TL 902 is newer, lighter and has a side handle for easier carrying.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
how do you get the back to open to put pouch in... brand new
из
@ann45280
You don't need to open the back.
You place the item to be laminated into the laminating pouch and then feed it through the machine.
Here's a video that shows how to use it.
из
Here's a picture of how the TL902 roller tension spring is assembled.
Here's a picture of how the back TL902 older model roller gear is assembled.
Here's a picture of how the back TL902 newer model roller gear is assembled.
Here's a picture of how the front TL902 roller gear is assembled.
Here's a picture of where the TL902 bottom screws go.
Here's a picture of the one TL902 side screw location.
If you need pictures of anything else on the TL902, just ask. Cheers!
Счет 1
1 Комментарий:
I have a part that is from the other side it’s long and has a circle at the bottom can’t remember where it goes
из
Добавьте свой ответ
anusharao.p буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 37
За последние 30 дней: 117
За всё время: 4,802
