Sony TCM-919 — это портативный и легкий кассетный плеер с функцией аудиозаписи. Это устройство 1990-х годов оснащено 3-значным счетчиком ленты, микрофоном, функцией автоматического отключения и фронтальной акустической системой.
Cassette player does not turn
The unit is actually a tcm 450 but the particular model was not present on the selection list. I found it in my grandma’s drawer along with a bunch of tapes, and I’m pretty sure it worked a year ago or so. when I shoved a tape in with aaa batteries, nothing happened. I removed the tape to see if the knob thing inside was turning, and it didn’t. Ibplayed with the volume knob and all the buttons, but it was failing to work. I can feel that the cassette player is trying to make it rotate— I can feel it when I touch it with my finger while pressing the ‘play’ button, but yet, nothing is happening. Plz Help!
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @pxlbluejay ,
Here’s a link to the service manual for the cassette player.
It has full schematics of the player which should help you find out where the problem lies. If a component is faulty it also has the parts list.
Hopefully this is a start to get the player going again
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
jayeff,
thanks a lot!
из
Probably a bad drive belt. If you can open it up and take a look chances are that the old rubber belt has gone soft and stretchy, without the right tension the motor wont be able to drive the pulleys. You might hear a mild screeching noise when you hit play, most likely the belt skipping. You can buy replacement belts on ebay or maybe amazon.
Счет 0
Добавьте свой ответ
Jay Kwon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 12
За всё время: 1,443
