Chrysler представила модель Town & Country 2008 года, которая поступила в продажу 16 августа 2007 года.
My radiator plastic cracked
Can i fix the crack in my radiator (the plastic right above the top transmission/ac coolant lines) with j.b. weld? I have tried every bars leak they make. And 1 other kind of stop leak but they jus get blown out by the pressure.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
A new radiator is the only real solution.
Был ли этот ответ полезен?
Счет 2
Plastic welding is an option. Plastic welding follows the same basic principle as metal welding. Add material, apply heat, everything fuses together. With plastic welding, there are lots of different types of plastic. However, plastic welding in the auto industry has been a thing for some time, so it’s more likely you can have success. Nylon is the plastic I read about in use in radiators.
An airless plastic welder is little more than a soldering iron, but I have found advantages to them over a soldering iron. Mostly the tip is very large so heat can be applied over a large area.
Счет 1
Добавьте свой ответ
Shawn Patrick буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 704
