Цифровая автоответчик-система Uniden с функцией оповещения о вызывающем абоненте, модель D3097S, впервые выпущенная 1 апреля 2012 года. Для ремонта этого устройства требуются обычные отвертки.
Cannot hear the caller speaking
When I receive a call I cannot hear the caller speaking but they can hear me, please help
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi,
Couple of things to try and narrow down the problem and hopefully resolve it.
a) When on a call press the speaker key and check if you can now hear the caller and be heard by the caller OK in speakerphone mode.
If this works OK then the voice reception circuit for the phone is OK. Go to step b).
If you still can’t hear the caller then there is a problem with the phone’s voice reception circuit.
If the phone service is VOIP service (phone service over internet connection, the phone is connected to a modem) try plugging another corded phone into the modem where the phone was plugged into and check if you can hear OK when on a call, as it may be a modem problem and not a problem with the phone itself.
If the phone service is connected to a telephone cable into the premises then there is a problem with the phone and most likely it will have to be replaced as Uniden doesn’t have spares.
b) When on a call press the boost key and check if you can now hear the caller OK
If you can hear the caller OK then the Boost option has resolved the problem.
If you still can’t hear the caller, then there is a problem with the phone’s earpiece receiver and the phone will have to be replaced as Uniden doesn’t have spares.
Here’s an image of the phone taken from the user manual that shows where the keys are.
(click on image to enlarge for better viewing)
Был ли этот ответ полезен?
Счет 1
This issue has nothing to do with the phone itself, just needs to reboot the modem the phone is plugging into.
Счет 0
Добавьте свой ответ
Baku Jewellery буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 15
За последние 30 дней: 58
За все время: 2,471
