Automatic Repair failed.. not enough space!
My laptop was working fine, then it got stuck on a boot up loop.. I'm stuck advanced options menu, but I can't use any of the options due to not enough storage! Any help would be great!
Это хороший вопрос?
Это хороший вопрос?
I would recommend going into the windows repair settings, and fully erasing/resetting the computer. If you are not able to do that, then here is what you must do:
WARNING: ALL METHODS I HAVE DISCUSSED HERE WILL FULLY RESET YOUR COMPUTER AND DATA WILL BE LOST IF IT HAS NOT BEEN BACKED UP
There is a method to keep the data however, that @jayeff suggested. He said: “the HDD (SSD?) [can] be removed and installed as a secondary drive in a desktop so that data can possibly be copied before attempting reset in original laptop.
Here's the service manual: http://h10032.www1.hp.com/ctg/Manual/c04... that shows how to remove the HDD.
Был ли этот ответ полезен?
Hi @timothymcevoy ,
Suggest that the HDD (SSD?) be removed and installed as a secondary drive in a desktop so that data can possibly be copied before attempting reset in original laptop.
Here's the service manual that shows how to remove the HDD.
That's what I would try to do first but that's just me.
Cheers
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 17
За все время: 1,435
