Двухъядерный процессор Intel Core i5 с тактовой частотой 2,5 ГГц (Turbo Boost до 3,1 ГГц) и 3 МБ общей кэш-памяти третьего уровня.
Charge port replacement question
Hi,
My computer has had trouble charging. I replaced the charger (onE of the pins was stuck) but the problem has persisted. I noticed some burn marks on my charge port and and looking to replace it. Which charge port is the correct one? and which repair guide?
my macbook is a A1278 model, serial number is: C1MMHY1KDTY3
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@tootscoots according to your serial number your MBP is actually a MacBook Pro 13-Inch "Core i5" 2.5 Mid-2012
2.5 GHz Core i5 (I5-3210M)
Intro.June 11, 2012
Disc.October 27, 2016
OrderMD101LL/A*ModelA1278 (EMC 2554*)
FamilyMid-2012
13"IDMacBookPro9,2
info from here which would make it a unibody model. Heerr is the guide for that Замена платы MagSafe DC-In в MacBook Pro 13" (модель Unibody, середина 2012 г.) and the part is available right here MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector. Изображение
Товар
$9.99
Был ли этот ответ полезен?
Счет 1
Charging ports are easy to damage. Constant connecting and removal of the connector cord can be hard on the port and move, bend, or damage internal components. Sometimes a dropped phone can also cause charging issues. If your phone or mobile device has stopped charging correctly krogerfeedback
Счет 0
Добавьте свой ответ
foster anderson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За все время: 391
