Google Pixel 2 — второй флагманский смартфон от Google, выпущенный 17 октября 2017 года. Телефон оснащен 5-дюймовым AMOLED-дисплеем и поставляется с вариантами встроенной памяти на 64 или 128 ГБ. Доступен в трех цветах: «просто черный» (Just Black), «явно белый» (Clearly White) и «слегка синий» (Kinda Blue).
Pixel 2 will not charge?
Pixel 2 will not charge? Should I replace the battery?
Это хороший вопрос?
Счет 1
3 Комментариев:
my pixle 3 wont charge so i dont know if disply is working or not
из
@estelle1379 ,
Have you tried a different known working compatible charger or charger cable or connecting the phone to a computer's USB port to see if it gives an indication that it is charging at all?
What have you tried?
из
@jayeff ya but screen is not working so i don't if its charging or not.
gonna give it to scrap now buying new one thanks for replying sir
but now dont worry about it
из
Добавить комментарий
2 Ответов
Hi Linda
If you’re not getting any response, it could be many different problems. First check for lint/dust/dirt stuck in the charging port that prevents the charging cable from making a good connection. Cleaning this out will fix your issue in many cases…
If you plan to replace the battery, I recommend getting a replacement charging port/USB board as well. That way you can diagnose all power issues at once.
If you are not experienced with opening phones, it is a good idea to get a replacement screen as well in case it is damaged during disassembly (return it if you don’t use it!)
Был ли этот ответ полезен?
Счет 0
Hey Linda,
Hopefully you’re not having that problem anymore. I recently stumbled upon the same thing with my google pixel two. I was wary over replacing the piece myself because I felt there was an alternate solution that would get the problem done, and I was right!
The easiest thing for you to do would be to grab a thin object, I used a zip tie, and dip it in alcohol, isopropyl is preferable, and just keep on trying to wedge out dirt from the charging port. I spent about 30 minutes on my phone and at first only tiny pieces came off, but as I kept on wedging even bigger pieces came out. Once I connected my charger into the charging port it actually went all the way inside! (only 3/4 of the charger fit). And now it’s working good as new, hopefully this makes your way and you can fix your phone!!
Счет 0
Добавьте свой ответ
Linda Lewandowski буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 30
За все время: 1,401
