GE Spacemaker Washing Machine Not Draining
Model: WSLS1100H0WW
I was given this combo unit a while back and it recently stopped draining.
Upon troubleshooting, I found:
* It will spin if select “Spin Only” and there is no water present.
  • If I put the hose on the ground, it will siphon drain. (I brought it outside to troubleshoot and I ran it with clean water, no soap)
  • The drain pump makes a humming noise
  • The drain pump is not clogged with anything
  • None of the hoses going to the drain pump are clogged.
  • I recently purchased a replacement Official GE drain pump and it still will not drain
  • The washer is able to detect when the lid is not shut because it beeps to close lid when it’s running a cycle. I’m not ruling this out, but it’s at least a little functional.
After a while of the washer not draining, it says “Drain” on the display. Basically it wants me to drain it so it can advance to the next cycle.
So, before I start buying more parts, I want to ask the friendly people of ifixit!
Thanks, Nicole
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @nikluv2020 ,
Does the new pump just hum as well?
Have you got a DMM (digital multimeter) and know how to use it when testing for lethal AC voltage?
If so measure the voltage at the drain pump terminals to check if the full voltage is being applied to the drain motor during the drain part of the cycle.
If not, perhaps you know someone who can safely test it for you.
Be safety aware when testing as the voltage will be at mains supply value i.e. 120V AC.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Yes, the new pump also hums, same as the old one.
My dad has a multimeter, which I have used before. I'm sure my dad will help me and we'll Google it. This is a great suggestion, thank you! I'll let you know how it goes
из Поделиться
Добавьте свой ответ
Nicole Sophia буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 39
За все время: 2,172
