Увеличенная версия десятого флагманского смартфона Samsung Galaxy, выпущенная в феврале 2019 года. Поставлялся с предустановленной ОС Android 9.0 (Pie).
How to refurbish screen
So I dropped my phone and my screen was working but it had really bad crack, it did not have any dead pixels but after a day the screen went full black, my question is can i just replace polarizer and should then the phone work or is it damaged and i need to buy a new lcd now? How to check that?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Well since you now have a black screen, the answer should be pretty obvious. You need to buy a new screen. The S10 plus uses OLED panels and whenever you break the screen whether it’s just the glass or you get a black screen, the only way to repair it is to replace the screen. OLED is very thin and fragile which just makes it difficult to repair.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Hi @dominik7111 ,
To add to the answer here's the ifixit Замена экрана Samsung Galaxy S10+ guide that may help.
из
So i can not just replace one part of the screen? Because i was wondering how it happend that it works one day and then goes complitly black and it havent got any dead pixels
из
yes you can't replace only certain parts of OLED screens and as a repair shop owner and technician, I speak from experience. The reason why it stopped working was because the OLED panel is fragile. When you cracked the glass that protects it, tiny shards of glass damaged it. Ever scenario is different. In some cases, people damage the OLED while the glass is completely unharmed.
из
What if the screen itself the pixels are all there and working fine but the top layer is cracked can the oled be saved
из
Добавьте свой ответ
Dominik K буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 13
За все время: 760
