Руководства и информация по ремонту блендеров Ninja.
Cracked Pitcher replacement?
I recently noticed sevrral cracks in my ninja blender pitcher which was a surprice as I only hand wash after each use . This blender is less than a year old so I was wondering if you could mail a replacement pitcher. I thought the cracks weren't bad but the fluid has started leaking out everytime I use it.
Это хороший вопрос?
Счет 1
5 Комментариев
Both my daughters have this happen to their ninja blender and we make salsa quite often and the leakage is annoying I was thinking about getting one but not now ,when I see this problem every were
из
I want a pitcher replacement for a ninja blender model ps101a
из
As @jayeff stated in the first answer to this question, iFixit is not a Ninja dealer and does not carry Ninja parts. If it's under a year old, check with Ninja regarding a warranty claim; otherwise you'll need to buy one. Ninja sells them directly to the public.
https://www.ninjakitchen.com/products/ni...
из
If the motor works so well then why don't ninja manufacturer work seriously on the quality of the jar ,why they are using poor quality plastic ?????!!!!!
из
Question: do any of you have any imagery of these units?
I am asking because our blender has caused a serious accident and I wanted to see similar units to compare notes on damage
Thanks, Neil
из
Добавить комментарий
4 Ответов
Выбранное решение
Hi,
ifixit is not a parts supplier for Ninja products and does not any carry parts for a Ninja Blender.
If the blender is less than 12 months old, check what the manufacturer's warranty says about replacing defective components. Usually the manufacturer’s warranty statement can be found in the user guide that came with the blender.
You will have to contact Ninja’s customer service section as per the warranty guide, about getting any replacement parts, either under warranty or perhaps not as they may deny any warranty claim as they may say that the damage was caused by the user. You can only ask.
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
I owned three Ninja blenders and each one of them developed cracks in the pitcher. I like the power of the blender but the plastic pitcher is poorly designed. I bought one with a glass pitcher and will never go back to Ninja!
из
The same thing happened to me. I am on my 4th replacement pitcher. Ninja customer service initially said they would not replace it, but after I asked for a supervisor they did agree to replace. I told them I thought this was a defect in their manufacturing process and asked if they would take it up the chain of command. Not sure anything will be done. But, this will be my last pitcher. If it breaks, I am going to purchase one with a glass pitcher from another manufacturer . May 15, 2025
из
Thanks, Neil
из
On my third pitcher in two years. Ninja has replaced them. Very poor design. Motor torque causes the pitcher to develop hairline cracks.
Счет 0
6 Комментариев:
I thought the same thing until I bought my third one about 6 months and it had the same cracks in it . This is a flaw in their design and I will be contacting them with the hopes that they have a redisign and a recall.
из
Good to know. I have been frantically searching for a replacement pitcher as I just noticed cracks in my blender today. I purposely bought a Ninja because I believed them to be of higher quality than the ones I have purchased in the past. Turns out, they crack just as easily. The blender is less than 6 months old and believing this to be the one for life, I threw out all the warranty details. Thanks for the information though.
из
I too purchased a Ninja blender thinking they are supposed to have great quality, only to find out after about 20 uses, NO drops, and hand washing, there is a crack going across the bottom of the pitcher and it is leaking. From reading many reviews I see it is a poor design and most likely cracks from torque, which makes sense as it is across the black piece where the blades connect to inside. I contacted Ninja and was told that even though it is only several months old, the pitcher is NOT covered under their warranty. Probably because they know they crack under regular use! I threw away a $30 glass blender I got at Walmart that I used for 3 years with NO issues, to get this expensive one because I thought it would be better. I’m going back to a glass one and will never buy anything from this company again considering they have poor customer service.
из
Mine is cracked also with only hands washing, haven't used it more than a couple dozen times. Totally bogus for such an expensive, albeit effective, machine. Definitely from torque stress based on the location of the cracks. It looks like they won't replace it, so I'm going worth JB weld! Hopefully it will do the trick.
из
@drbobbi
Allow it to fully cure before placing any food in the pitcher.
Most 2 part expoxies are food safe but only once they have fully cured.
Follow the directions on the label to know how long to wait.
из
Показать ещё 1 комментарий
I put silicone on mine, the waterproof boat silicone, and it is holding up so far. Would really like to get a replacement though.
Счет 0
1 Комментарий:
Nise Glad the boat sillicone is holding up for now. A proper replacemant would definetly give more peace of mind tho hope you find one soon
из
Same here. Hand washed (run the blender with water and soap in it to clean, has never been put in the automatic dishwasher). Not that old. Same hairline crack in the base that everyone is reporting, here and elsewhere. You're never going to get a company like this to voluntarily admit to a design defect, it would take a class action suit to get any results. Not that those ever do any good for the customers who'd get a few pennies on the dollar back, it's always just the lawyers who skim off 40 - 50% off the top who benefit. Would be nice to stop them selling these defective products though. After looking around for a replacement pitcher at a sensible price and failing to find any, I'm switching back to the brand I had before, with a less powerful motor that burns up if it gets jammed up with something too hard, but had a solid reliable glass pitcher. A $40 motor is cheaper to replace than a $90 plastic pitcher :-(
Счет 0
Добавьте свой ответ
Terri Baker буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 62
За последние 30 дней: 282
За все время: 19,503
