Выпущен в июне 2012 г. / Процессор Core i7 с технологией Turbo Boost / До 1 ГБ видеопамяти GDDR5
Mid 2012 MBP Hardware Upgrades
I want to upgrade my laptop’s current HD & RAM, possibly removing the Optical Drive as well since it doesn’t work anymore.
Any Suggestions ?
It’s not for super critical work such as Audio or Video Editing, I just need it to be faster, or as fast as it can get.
Thanks in advance.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
To start with I would bump the RAM to 16GB which is the systems limit Замена оперативной памяти в MacBook Pro 15" Unibody (середина 2012 г.)
As for as drives I would go with a 1TB so you have plenty of space. I would go with a SSD Vs HD as its just more rugged and uses less power Замена жесткого диска в MacBook Pro 15" Unibody (середина 2012 г.).
The one issue you do face is the HD SATA cable will likely need to be replaced if you still have the original HDD in the system as the original cable was not able to run at the higher SATA III (6.0 Gb/s) data rates the SSD will push without encountering issues MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable I would also apply a strip of electricians tape on the upper case where the cable crosses over and explained here Your Hard Drive Cable Is A Ticking Time Bomb
The last issue is making sure you don’t damage the cable installing it. A common failure I see is people crease the cable which damages the thin foil wires with in the cable. I use an old BIC pen ink straw as a bending brake to form the bends so I don’t exceed the radius of the straw.
I would leave the optical drive alone as it needed for structure and with one large drive you should not need a second.
Replace a damaged cable connecting the hard drive to the logic board in your laptop. Изображение
Товар
$19.99
MacBook Pro 15" Unibody Mid 2012 Жесткий диск Изображение
Инструкция
Сложность:
Умеренно
20 - 30 minutes
MacBook Pro 15" Unibody Mid 2012 Оперативная память Изображение
Инструкция
Сложность:
Легко
10 - 45 minutes
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
I think the original HD was already replaced because the HD in it now is a 1TB, but good looking out with regards to the HD Cable installation.
из
An SSD will give you a perceived 100% speed increase.
из
That trick with the old bic ink straw to limit the radius of a bend for the ribbon cable - I'll be keeping that in mind.
из
Добавьте свой ответ
immanueltnt буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 23
За все время: 249
