Ноутбук от Lenovo, способный работать в режиме планшета.
How to replace entire lid and screen
Hello,
My laptop was dropped. The screen cracked and lid was dented. My touchscreen was working but not anymore. I have a feeling that it’s a separate issue but wanted to replace the entire top (lid, screen, and whatever else). What parts do I need and how do I do it? Thanks for any help!
/BTL
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @btl02 ,
Here’s the hardware maintenance manual for the laptop.
Go to p.61 to view the necessary pre-requisite steps and then the procedure to remove the LCD panel.
On p.87 Item #8 you will find the part numbers for the lid. Search online using only the part number appropriate to your particular model variant (see columns re model number) to find suppliers of the part
For some reason the part numbers for the LCD assemblies are not shown in the manual but here’s a link to the LCD assembly and other associated part numbers for a Yoga 720-13IKB
Click on Select Commodity and then click the checkbox on LCD Assemblies (2), LCD Consumable tape (1) and LCD parts (6) to find the part numbers for all the parts in the lid etc.
Here’s the link for a Yoga 720-15IKB as you didn’t specify which model you have.
If you are unsure about which LCD panel to get for your model, usually the part number can be found on the back of the panel somewhere so that you can verify that you’re ordering the correct one.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
I have not had the time to act on this, but thank you for a very comprehensive instruction. It's much more than I expected. Thanks!
из
Добавьте свой ответ
BTL буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 768
