Ремонт и общая информация о ноутбуке-трансформере 2-в-1 Dell Inspiron 5379.
one major problem is over heating
Dell Laptop 5379 2 in 1. Working well after Factory image reset when except diagnostic start nothing was starting, even resetting was not happening.
Now one major problem is over heating.
a). 2 Years old but very sparingly used. Battery showing only 54% of the life time.
Bios & Windows updated.
Still over heating. Auto diagnostic showing battery problem.
After the LAPTOP kept under fan for two to three minutes folding it ( it is foldable machine)., ventilation in fan direction, it is coming to normal cool.
Is there anything we can do to bring it to normal, if so, how.
Это хороший вопрос?
Счет 0
1 Комментарий:
Hello i have this problem too and it’s been quite disturbing l. Please were you able to resolve yours and how?
My fan keeps running so fast and i can actually hear it. What can i do?
из
Добавить комментарий
1 ответ
Hi @hydind
Have you checked that the fan vents on the bottom of the laptop are clean and clear of dust etc you didn’t say?
Can you hear if the laptop fan is operating or feel the air coming out of the vent indicating that the fan in the laptop is operating, you didn’t say?
If you can’t hear the fan or feel the air coming out of the vent then there may be a problem with the fan.
As the laptop is only 2 years old there shouldn’t be a problem with the thermal paste on the CPU drying out yet which can also cause overheating. usually it takes about 4 years for this to occur but it may depend on the environmental conditions where the laptop is located I suppose
These are the two major factors that cause overheating in a computer i.e. faulty fan (or blocked vent) and dried out CPU thermal paste.
Here’s the service manual for the laptop, taken from this webpage.
Go to p.43 to view the necessary pre-requisite steps and then the procedure to remove the fan. This will allow you to check that it is still connected properly and also to see if it is working OK or not.
I don’t know what you used to ascertain the state of the battery but get a second opinion as to its condition by creating a Win 10 battery report. In the results check the Design Capacity value in comparison to the Full Charge capacity value to see if it is also at ~54%, (you have to do the maths ;-) Batteries are meant to be used and if not regularly used and charged can deteriorate and eventually fail.
Hopefully this is of some help.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
CANDU буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 34
За все время: 796
