Lenovo ThinkPad X1 Yoga 2nd Generation — это 14-дюймовый ноутбук, выпущенный весной 2017 года, который можно идентифицировать по номеру модели TP00076C.
USB C ports non functioning at all.
Is there any way to replace these parts so i can charge it again?
Это хороший вопрос?
Счет 0
2 Комментариев
Hi
Have you checked the status of the USB-C ports in Device Manager, you didn't say?
из
its dead atm cause i cant charge so i cant check, its a gen 5, for some reason this option is not avalible , any replacement parts?
из
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
You may be out of luck as far as easy replacements are concerned as the two USB-C port are hard mounted on the motherboard.
Are the ports physically damaged at all?
If not then it may still be a software problem and it may be easier to temporarily replace the battery with a fully charged compatible replacement battery and check the status of the USB-C ports rather than removing the motherboard and to replace the USB-C ports as they may not be faulty.
Here’s the hardware maintenance manual that may help with either option that you decide to go with.
Был ли этот ответ полезен?
Счет 1
I had one c drive fail. It was covered under warranty. They replaced the motherboard. Apparently not uncommon problem. I WATCHED part of a one and half hour video as someone repaired the port with welding equip or something. It was not an option for me.
Счет 0
Добавьте свой ответ
Yahir Nava буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 22
За все время: 902
