Canon Rebel T6i — популярная полупрофессиональная камера с 24,2-мегапиксельной матрицей, предназначенная для любого пользователя. Это руководство, также известное как EOS 750D и EOS Kiss X8i, призвано помочь в устранении ряда распространенных неполадок, которые могут возникнуть при обычном использовании.
Screen does not work Canon EOS 750D
My camera takes photos and records video but the screen remains black at all times. I think a connection is broken. Any suggestions on what I can try myself?
Thank you!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @myrah ,
With the camera turned on, try shining a torch at an angle close to the LCD screen and check if there are any images visible at all. They will be very faint so trying this in a darkened room may help to see them if they are there.
If there are images then there is a backlight problem with the LCD screen. This could be due to a faulty screen flex cable connection (at either end, screen or motherboard), a faulty LCD display or a problem with the motherboard.
If there are no images, then it may be a faulty LCD screen flex cable connection (at either end, screen or motherboard), a faulty LCD display or a problem with the motherboard.
I realize that the possible causes of the problem are the same for both scenarios but if it is only a backlight problem and replacing the screen doesn’t solve it, then you are one step closer in troubleshooting the problem on the motherboard by knowing this.
I don’t know the camera but I think that the EOS 750D is the same as a Canon Rebel T6i as they share the same user manual and also use the same LCD screen. (supplier example only)
If you wish to try it here’s the ifixit Замена ЖК-дисплея Canon EOS Rebel T6i guide that shows how to replace the LCD screen in the camera. At least you can check the cable connection to the screen and if it appears to be OK maybe replace the screen as it is not too expensive.
If you decide to replace the screen there are other suppliers online that may suit you better. Just search for Canon EOS 750D LCD replacement
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Myrah буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 2,947
