Top half of screen is dark
Top half of the screen keeps going dark, and have little bright shadow on the screen
Это хороший вопрос?
Это хороший вопрос?
Hi Mark, I have a Samsung UE50JU6800 that has just developed the same issue.
Whilst i dont have a definitive answer yet, i found a video from Shivamm Rane on youtube ( a search on Youtube will find it, unsure of iFixits rules on links ) that details replacing either the entire LED light strips or individual LEDs on Samsung TV’s that cause this issue. It will be a few weeks before i attempt my repair but hope this helps you on your way.
The replacement LED strips seems quite readily available on Ebay.
If i am successful in my repair will post a guide.
Был ли этот ответ полезен?
Was the repair successful?
U mnie jest na odwrót na dole jest ciemniejszy ekran
@szmondjabin in that case your bottom backlight strip has failed. Replacing it should fix that.
@szmondjabin w takim przypadku uszkodzony jest dolny pasek podświetlenia. Wymiana powinna rozwiązać problem.
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 28
За всё время: 1,165
