Gateway FX6840 — это настольный ПК на базе процессора Intel Core i7.
How to repair RAM at home?
Hi Ifixit Support Team, I am new here, I am a user of Gateway Laptop. My laptop ram is faulted and my laptop is going to an on/off situation many times. Kindly Ifixit Support Team, tell me how to remove the fault of the laptop easily.
Это хороший вопрос?
Счет -1
1 Комментарий:
need the laptop model to properly help you
из
Добавить комментарий
1 ответ
Hey George,
I have got to say using a Gateway may not be your best choice, but I digress.
Are you getting a BSOD?
You can try opening and removing the RAM and re-installing it, making sure to have a good fit. Or replace the RAM if that is an option.
I know this isn’t RAM related but you could run a CHKDSK from the run dialog box and check your hard drive.
There could be a potential for a failing power supply as well, or a virus.
Without more information it is really hard to say., but those are a few things to try.
Hope this helps.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
George Bell буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 344
