Aquos LC-13B2UA — это ЖК-телевизор, созданный компанией Sharp. Габариты Sharp Aquos LC-13B2UA составляют 33 × 7,6 см.
Plugged in and popped
Plugged in and popped, now doesn't turn on. We found out that all our outlets in our basement were getting too much power. I haven't attempted to fix, figured TV was done. I thought this site might give me some answers. I have no problem taking it apart if it can be fixed…is it worth it or a lost cause?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @cindylee ,
Just verifying that the TV is an LC-13B2UA?
If so, looking at the user manual for the TV it has an AC/DC power adapter which supplies 12V DC power to the TV.
If the power outlets were supplying too much power the adapter may have failed and not the TV.
Plug the adapter into a power outlet only and check if there is 12V DC when measured on the output plug of the adapter.
If the adapter output voltage is OK you have to remove the back cover from the TV and inspect the board where the power plugs into. Check for a blown fuse or surge suppressor (images to show what they look like) near the power input or other blown components on the board.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Cindy Houston буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 17
За всё время: 337
